TOWER PRO MG-995... anyone tried on helis?
    TOWER PRO MG-995
    (METAL GEAR SERVO)
    (ULTRA TORQUE)
    13 kg Torque
    High-Speed
    Weight:55.2g
    Operating speed:0.13sec/60degree(6.0V)
    Stall torque:13.0kg/cm (6.0V)
    Temperature Range:-20 degree to 60 Deg
    Dead band width:4usec
    Operating Voltage:4.8V~7.2V
    Structure Feature: 3 pole ferrite, dual ball bearing, 3 metal gears and 1 Resin metal gear, connector wire length: 32cm
    would like to know how they perform...
    $30+ bucks is pretty darn cheap digital with stunning specs...
    does it live up to its specs??
    am really interested in these since they are really cheap!
    sar.ratha@me.com
    DEVIL
    ratha, im interested to use this servo also... but not on helis! more on plane rudder.... i dont dare risk my machine!
      why not? gears easily stripped?
      i think if it works well on buggies or trucks... should be fine for helis right?
      sar.ratha@me.com
      DEVIL
        Hello folks,
        I have tried the servos, here are my comments:
        The torque is there, the speed is there. Now... the things to improve..:
        1) The centering of the servo is bad...meaning when you move the servo to the extreme left or right...it will bounce before it stop at a position. same goes to when you release to neutral position it will bounce towards the other direction before it stops...
        2) Friend used it on a buggy the servo burned...
        3) The gear get slop easily...even after one run.
        4) The resolution of movement is not too great, but acceptable.
        Having said that, its still a cheap high torque servo for those that are not too fussy.
        I have tried it on my Sceadu...no problem, tried in on my Savage MT perfect...tried it on my 60 size plane also no problem...
        The servo movement on the ground might look scary due to the bouncing moving...but in flight it didn't show any bouncing of aircraft..
        Suggestion for use:
        MT and buggy on both steering and throttle, you get great braking power.. reason for use, basically its safe and the bouncing doesn't really matter and its cheap...
        Rudder of plane, check out your ability to knife edge.
        Heli and other parts of plane, can use...no problem for me so far, but at your own assessment. So far I have it on all channel of my plane no problem.
        Good Luck and have fun..!
        Regards
          I hate to say this, but I've got them on me Sceadu 50.... but it has yet to take off thr ground.... anyone care to do a test flight for me, as well as test these servos??
          alfer
            I dun mind to test flight for u
            Tx : yet to know
            Heli : yet to know
              In control engineering theory, we call this observation as underdamp oscillation (i.e. the servo is unstable)
              Normal fly around is all right because servo is not constantly changing its position thus oscillation is avoided.
              However if hard 3D (i.e positive and negative pitch constantly), u might feel some unexpected movements.
                I do not wanna put my trust on a $30 servo especially when $1.5K worth of equipment is in the air...
                TREX 500 ESP
                Futaba T12FGH
                  Hi Art,
                  I know what you meant, but just my 2 cents about pricing...
                  I don't know if $30 should be a good representative of = no good, cannot be trusted? I have and had seen many expensive $120-$180 futaba and hitec servos fail on me and my friends before too...
                  If Towerpro is to sell them at $300 per piece, wah...become very good servo.
                  Regards
                    erm...disagree...experience is such....more ex...= better....sad but true fact....
                    Personal opinions though
                    TREX 500 ESP
                    Futaba T12FGH
