Anyone have the technique to lift off honey bee T?
    I am struggling to lift off my honey bee and attempt to hover in the air.
    Everytime i increase the throttle slowly, the heli will slide to the left.
    Should i increase more on the throttle speed when honey bee starts to slide toward the left?
    Any suggestions?
    One technique that many newbie lack in is ability to trim the heli.
    The only way to trim a heli is to fly it then trim it. Some may ask, then how I suppose to trim when I cant even fly it?
    Yeah, answer is simple and straight forward - U need someone else to trim yr heli. Once it is properly setup and trimmed, you then proceed to learn with the "correct method" Only this way will make yr learning curve easier.
    If u insisted to try w/o others help, then I suggest u draw a box 1 feet by 1 feet on the floor and attempt to keep the heli in the box while slowly increasing the throttle. Keep doing it making sure tail is pointing towards u at all time. U should be able to hover one day.....
    Mike
      where do u live dude ? i own and fly the same heli as you
        Here's the link to Mike's suggested white box technique. Pretty good. Promises to get u hovering in 10 battery packs if u follow it striclty
        http://www.dream-models.com/eco/flying-index.html.
          I staying jurong west
          I stay jurong west st61
            hi, here is my limited experience:
            1) if it slides to the left its quite common, just apply a little aileron to the right while you throttle up slowly.
            2) if the head turns to the right, meaning high trust on the tail rotor, adjust the rudder slider to the left.
            3) use training skids.
            4) key thing about this heli is that your fingers have to be quick. with time, you will know how your heli will behave so you anticipate its behaviour.
            5) like most, if not all, helis you need constant input to the sticks to keep it stable.
            6) make sure your batteries are well charged. it is difficult to trim with weak batteries.
            GOOD LUCK!!
              I found a cheater's way to get it up in the air, slightly elevate the left skid, no more than 0.5cm. It will reduce the tendency to move towards the left and make it easier to get it to hover, u can then trim from there.
                just apply left aileron then it won't slide. it slides due to the thrust of the tail rotor.
                JR 9x
                Raptor 50 SE
                Raptor 90 3D
                Mini-Titan
                Superb machine!
                Piper Warrior 2 Pa-28-161
                Lycoming O-320-D3G 160HP
                Pilatus PC-21
                  wldn't left aileron makes it slide more to the left?
                    Thankyou all, for your advice!
                      oops my bad read wrongly. apply RIGHT aileron
                      JR 9x
                      Raptor 50 SE
                      Raptor 90 3D
                      Mini-Titan
                      Superb machine!
                      Pilatus PC-21
                        i tried to trim the heli by tying a string to the bottom of heli to the floor....
                        it hover alright untill i got the trimming correct....
                          don't suggest doing that, a training skid is a better alternative, and its cheaper then a crash repair.
                          XRB SR Lama
                          Robotis Bioloid
                          Robot Bear
