Syma fly dragonfly
    Syma fly dragonfly
    Can anyone gip me tips on y tis heli that i have will spin lyk a dizzy bird when if flies..so i cat control it...Y?
    from the spec, its has a adjustable gyro, play around with it.
    if not then check the tail motor, also check its wire
    i suspect there is a mixing adjustment somewhere, check you manual
    lastly is the batt fully charged ? its stated 3 hrs for 10 mins flight.
    XRB SR Lama
    Robotis Bioloid
    Robot Bear
      Hey..the batt is fully charged...about the mixing..i dun really noe where it is...
        can u tell me from where u get the info from...
          Need some more tips from the pros in heli flying out there....
            i found the spec info from some website that sell it, not much info.
            its a 2ch heli, meaning only go up/down and turn left/right.
            so its a basic hovering heli, its not design to go forward/back or sideway.
            ok maybe no mixing, have you try the gyro ? the manual should have some info.
            XRB SR Lama
            Robotis Bioloid
            Robot Bear
              syma dragonfly
              I've got one of these heli, in fact my first one. First you must open up the canopy and you'll the receiver. The trimmer is located just below the on-off switch, beside the tail-rotor input connector. Give me a buzz at 90624735 and will gladly help you.
                About the trimmer..i noe but i dun noe where to trim...thats wat i wanna noe..
                  Trimmer
                  For me, I just tweak it anti or counterclockwise until it is almost stable.
                    woohooo...any more help??
                      Thanks to all hu helped...my heli is good now
