Watch out for gyro position!!!
I was trying putting gyro in different location for my flybarless TRex (cyclic gyro).
This is what I find out... (Based on my finding only):
For TRex, the least most vibration is still the tail area... the usual area where u mount the gyro. If u want to mount below also can but have difficulty in calibration/tuning... unless u are talking about remote gain gyro.
In front, the vibration is up and down motion.
If it is near motor, some motor do generate alot of EMF that will cause the gyro to go oscillation (your tail/cyclic...depend where u want to control it) tend to wag.
The another least vibration will be at the top of the servo compartment (HDE) but have problem mounting canopy.
Another alternate is to mount near the tail usual area but on the side instead.
EDIT: Oh... one more place will be in front of the servo compartment (HDE) or above the battery
SH
I've tried in front, the motor EMF seems to effect the gyro. Also, when the battery gets hot, the gyro will start to drift.
With GY401, no problem with the gain adjustment. The main problem is I can't see the LED since it is facing downward.
I'm considering to mount the gyro vertical, so that I can see the LED from the side, but not sure if that will affect its performance.
