Found this "new" tail configuration at rotor. It come with steel shaft and a GWS 6050 pro.....of cause all the necessary nut and C clip. You just slip it onto the existing gear (tight fit) and put in the locking nut and is done....very stright forward.
Manage to test fly and it holds pitty well too. Painted it black as I dislike the original color of the GWS pro.. not sure how it perform under high head speed ....can it hold against sudden change of head speed and so no....need to test it out. Oh it cost $3.5 a set. The main disadvantage is it will easily break under hard contact. As it is direct monut onto the steel drive shaft. BTW heat generate by the tail motor is low as at the end of 10 min flight I can hardly feel anything...
