Throttle Jockey Pro & gyro 501 setup in 9xII
    Hi Guys,
    I bought a throttle jockey pro and wonder what channel should I plug the throttle jockey to.
    I plug it into Gear channel, but when I set the gear channel in 9xII to be GOV, I cannot calibrate the Throttle jockey pro. But if I leave it as Gear, I can do calibrate it.
    In this case, what should channel should I plug my gyro to? Please advice. Thank you
    leave it to me to fix it la.
    i will sort it out for u
      thanks fren!
      btw way, found the cause to the sudden increase in RPM, broken sensor... I must have mounted it too close to the magnet. I will order one from the net afterwards.
        use gear channel for the gyro aux, and use aux 3 for the tj pro.
        JR 9x
        Raptor 50 SE
        Raptor 90 3D
        Mini-Titan
        Superb machine!
        Piper Warrior 2 Pa-28-161
        Lycoming O-320-D3G 160HP
        Pilatus PC-21
          Hi Brandon,
          I have used the aux 3 for adjusting the co-pilot.
            i think in that case you can use aux 2, but change the mix from aux 3 to aux 2 then should be fine.
            JR 9x
            Raptor 50 SE
            Raptor 90 3D
            Mini-Titan
            Superb machine!
            Pilatus PC-21
              off hand, I can't remember what is connection on the reciever now.
              By the way, after connecting, can we use the governor function in the JR 9XII controller or we leave it as Gear?
                leave it as gear. the GOV is not design for throttle jockey
