i saw this ducted fan at helihobby website. Does any one know where in singapore can i get this ? Is this type of tail rotor gd ?
ducted fan system for tail rotor
The GWS fans can be bought in singapore but i don't know about the nice carbon fin and mount.
Came across this picture while looking around the internet for micro heli things, looks pretty nice you could probably do something like that after dropping by rotor hobby like HZM said, or the much disliked champion hobbies at kelantan lane
This is the "pronet", that's supposed to be on world tour or some-such-and-such.
i saw this idea in a recent issue of MHW... see if anyone has broken carbon main blades from a nitro heli, take the carbon sheets out, cut and glue them as needed.. cheap!JR 9x
Raptor 50 SE
Raptor 90 3D
Mini-Titan
Superb machine!
Piper Warrior 2 Pa-28-161
Lycoming O-320-D3G 160HP
Pilatus PC-21
Neo, my advice is to avoid it. I've tried the EDF 50 before and it drew 3+ amps at full throttle. The weight is also another factor. It adds a lot of weight to the back and this combined with the high amp draw will drop your run time tremendously. All of my packs were destroyed by the high amp draw
Unless you can get the EDF50H do not try it. AFAIK no LHS carries the H (high voltage version). The H version would have a lower amp draw and would be usable.-Feda Dragonfly
-Hornet 2
-Pilot OK Turmeric
-Zoom Zoom 4D
-Hornet X3D
-Hornet X3D (yet to setup!)
-Formosa 1
-World Models Spot On 50
-HB King 2
-World Models Groovy 50 F3A
-RICCS F18 EDF
Controlled by 9CHP
(Temasek Poly AMIG)
i'm using the edf 50 motor with a 3020 for my tail motor ( i only put that in because i've got a few spare ones from a few old DF units ) and everything seems ok. Might be a different story with the shroud an small little DF blades like fit tried, though.
Thing about the drawing-2-amps-at-7.4v : i dont think the motor will always be at 7.4volts and full power when you're hovering.
i've tried an IPS motor in the same setup and that worked ok as well.Perhaps an IPS motor in a DF shroud with a 5 blade df blade would be good? I think the IPS would be a higher turn motor and be a good approximation of the edf 50H that Fit suggests
derrick
