Make sure u calibrate the controls.
Note: u may have to selct Inv on certain controls, depending on what orientation ur tx is set to.
NOT TOO SURE IF DIFF TX AHVE DIFFERING SETTINGS.
I'm using OPtics6 w/ FMS ver2 Beta, the steps are:
1. Plug the serial cable to both PC and Tx
2. Turn on the Tx
3. Launch the FMS
4. Go to controls >> Analog control
5. Select Serial PIC interface (depends on your connection)
6. Click on Resources Button
7. Select the Port w/ 19200 Baud then click OK
8. Select Mapping/Calibration Button
9. Click Calibrate
10. All the level in Channels 1 to 6 will be randomly up/down
11. Move both your stick up/down - left/right
12. Then the level in Channels will be stay in the center
13. Move the right stick to center for 3D or move it to lowest for normal flight
14. Click Next, then Finish
NB: You must set the Tx mode to PPM
Hope it's help ...
1- Throttle = Pitch
2- Ailerons = Roll
3- Elevators = Nick
4- Rudder = Tail
the former is for plane control and latter is for heli.
you may need some servo rev on the some ch, so if you rev throttle,
you also have to rev your pitch.
