Today, I took out my TT Pro-36H engine and tried to turn it but found that the whole thing is jammed. So I removed the cylinder head, the backplate and the carburetor. Apparently, after 1 year plus of not using has caused the fuel residues in the engine to dry up and now the piston is stuck in the outward position.
From what I see, the crankshaft looks ok and movable.
Thinking of stripping apart the whole engine to clean it. But how do I free the piston?
Never know that. I thought that by the time the whole engine cool down, the piston will be cool down also. So, if everything went down to room temp, then the piston shouldn't have got stuck even when it is at the top postion. I remember the last time (1 yr + ago) when I tried turning the crankshaft, it will moving every smoothly.
