Bladerunner motors
    Bladerunner motors
    Bought the bladerunner heli from Carrefour over the weekend, and the bottom rotor motor died on me after just 10 flights! Does anyone here have the same experience with dead bladerunner motors and replacing them? Need some advise from those who have done it before, e.g. where to buy the replacement motors in Singapore.
    Thanks!
    sf.
    try rotor, they use to sell the heli, might know the motor replacement.
    XRB SR Lama
    Robotis Bioloid
    Robot Bear
      Thanks! I will check with them next week then.
        alt, you can bring the motor to simlim tower / electronic shop to find.
        there should have some printing of model number on the motor.
        good luck
        XRB SR Lama
        Robotis Bioloid
        Robot Bear
          It's the N20 motor, which is the same size. But it can not proivde the same power. The magnet used in the motor of the Bladerunner is stronger than normal motor. Try this, open up the end bell of the damage motor. Most likely the brush are damaged. Just replace it with the new end bell from the N20 motor.
          So far have not found any LHS to carry this replacement motor. Do post if if you happen to find it.
          Good luck.
          VinCopter
          Share the joy of flying . . .
            N20 motor
            You can find this motor B2 Simlim Tower, corner end shop (orientation is by the side of Sungai road/canal) Name of Shop is Printex.
            Good luck
            Vifo
              Hi, how much would each motor cost? Thanks!
                Wow so many replies from helpful people here. Really appreciate it - thanks!
                  Does anyone know how to replace the motor in the blade runner as one of the screw is hidden by the gear?
                  Moreover, anyone know of any better motor which i can replace the current one that is in the bladerunner
                  Thanks in advance
                  Thanks!
                  sf.
