Vladimir 's Snipe
    Vladimir 's Snipe
    Build log for Snipe.
    Kits comes very complete with all hardware, lots of details are already done like pull strings threaded, manual was clear , experienced builders should be able to complete the build fairly quickly.
    Weights
    Wings
    Aileron control horns assembly
    Glue gf pads with medium CA, attach support pins, make sure they are able to move freely.
    Test fit horns and pins, make sure no binding throughout whole range of aileron movement. Sand part of the horn if necessary.
    Mix 15 min epoxy and fit the horns in. CA the pins down on wing alignment groove.
    CF with thin CA over groove to hold pin in place
    Peg
    Mark and open up slot for peg. Dig out the rohacell and test fit peg
    Glue in peg with epoxy as per manual.
      Tails
      Slots for the control horns are already marked on the tails.
      Pen knife cut the slot and CA in the horns
      Insert in spring for tails
      Align vertical stab with wings , elevator attached. Glue down with CA then apply GF patch.
      Hook on the pull strings as per manual
        Finishing up this build thread
        Fuselage. The fuse is follows the Blaster 3 style fuse with the boom extending all the way to the nose. This makes the whole fuse very strong and servos very easy to access.
        Servos used MKS DS6100.
        Battery all the way forward, i m using 1s 680mah. mark out where the servos start. Remove the stickers from the servos as they will be glued down directly
        Align servos starting from the first one in front. Alignment follow as per manual. Horns used are smallest horn, 7mm from center. It provides more than enough throws.
        Trim and glue the pushrod sleeve to the carbon support pc
        insert the pushrod and make Zbend
        Final fuse layout
        Antenna placement below make it as parallel to wing as you can
        I ended with no weight needed in front, CG 67mm, AUW 247g.
          when you get bored of catching thermals, do some acros
          1min mark, watch for the inverted handcatch turn around.
            Power!
            Akira.
            Planes - Vladimir Maxa4/Vladimir Blaster3/Vladimir Elf
              Nice...
                Launch practice today.
                Average ard 50m, peak 55m.
                Surprisingly without ballast and with 30grams ballast launch heights about same. Need to work harder, some gorilla in USA just launched snipe to 90+ m.
                Without ballast
Name:	snipe 29 march 2014.jpg
                With 30g ballast
Name:	snipe ballast 29 march 2014.jpg
                  Hi Pang,
                  What's ur AUW and cg?
                  I today flew at ohr average also ard 50m, highest 54m.
                  AUW 260g , cg 63.5mm, ballast 30g.
                  Yong
                    CG 67mm, AUW 247g without ballast.
                    Join us at CD field Sat mornings , more fun flying together.
                      Morning still in dream world . Haha.
                      My ballast I think is permanent in. Find very difficult to fly with the Auw 229g. Only able to fly in no wind conditions.
                        Without ballast, is your cg same? At cg 63.5 it should be able to handle some wind, prob up to 4-5ms.
                        I like unballasted more and normally won't use unless the plane is flying backwards in cruise mode, while others like sherwin prefers ballast. Add ballast for thermals not wind if possible. The main concern is can you launch a heavier plane well and do you want to give up a little sink rate to cover more ground (to search for thermals or get away from sink). I find less effort needed to launch lighter plane. Experiment and see what suits you best.
                          Without ballast cg is at 70mm. Find it hard to penetrate thought wind and most of the time can't get the plane back, even with some nose weight to cg65mm
                          And with ballast I can launch average 50m, without ballast only 45m.
                            Today flight at ohr
                              Nearly break the wing with hard throw. A lot of crack line needed repair
