Today is my second experience I lost a SkySurfer obviously due to some technical or other problems that might be the cause that sent my glider out of control. It started well with not problems that my glider was able to manouevre and return with safe landing. After my fourth flight when the glider was still within visual range (about 300-400m) the glider suddenly made a sharp turn and head sharp down at erratic course.
I suspect this problem could be due to the following reasons :
1. ESC (20amp) could be over heated? Is 20amp ESC sufficient for this model that comes with the motor?
2. Futaba digital RX 2.4ghz 6 channel lost signal with TX?
3. Environment interference?
For the experienced flyers, I would like to hear your suggestions on prevention of future incident and the right type of electronic gadgets to be used on the glider. (Note: I use the Futaba T8J FHSS and Futaba RX 6 channel.)
Thank you for your attention.
