im involved in a glider building competition and i need some help .the glider can be of any size and any design .it just need to fit through a door 2.1 m high and 1m wide.i also need to fit on a trolley to the glider to move down a 10 m ramp and take off.the furthers glider will win a trophy.so now i have to built a glider which can glide far without any electronics and motor.
does any one have any plans or design for a glider which i can built easily.
-how do i make a wing with creates lots of lift(wat aerofoil shape shall built.
-the shape of the fuselage
-find the correct cg(put nose heavy or tail heavy to have longer flight
-wat material
-high wing,mid wing or low wing
-how long should i build the wing and fuselage(ration between fuslage and wing)
-wat material
