Composite Gliders
    Composite Gliders
    When we say composite gliders, is the wing still make of balsa ? Have been checking out soaring composite and other gliders on hobbyking, but getting confuse the materials use on these composite gliders.
    E.g. Soaring composite - E-Wasp and Eagle 5.... is the wing Balsa ?
    Thanks in advance for response to newbie question.
    Jonathan
    In a sense composites are actually made by making a sandwich of different materials.
    Eg: wings can be made of a sandwich of foam, balsa,fiberglass. Each material has its unique mechanical properties and when combine together gives and overal structure that has all the properties needed in a wing. You want the wing stiff, yet resilient when you need it to be.
    Try this. If you take a thin sheet of fiberglass and coat it with epoxy and let it cure. After curing it will still bend. only after multiple layers of fiberglass will eventually the plate will be strong...stiff but heavy.
    Now take 2 thin sheets of fibreglass and sandwich a thin balsa between them. Apply epoxy on both sides and let it cure. Put a heavy book on top of it while it cures. Once cured, you get a surprisingly strong structure that is light weight. For the same thickness as trying multiple layers of glass.
    Typical composite materials
    Your bread..
    Carbon fibre
    Glass
    Kevlar
    Your sandwich filling
    Balsa
    Rohacell
    Herex
    All these comes with different thickness And weights so it all depends on the designers goals on strength and weight of the complete plane that determines the mix of materials.
    Do you feel the RUSH....!!!!
      Hawkeye, thank you for your education. appreciate it.
          If you want to see a nice diagram of what I'm talking about, go here
            Hawkeye,
            this is great information ... thank you. ANy idea what is the material on wing for E-Wasp from soaring composite ?
            porksoda,
            The reason I asked is I miss understood that composite refer to all wings and fuselage is all fiberglass or carbon...then I saw some picture of crash compsite and seems to see balsa breaking....
            Jonathan
              Originally posted by Hawkeye View Post
              Your bread..
              Carbon fibre
              Glass
              Kevlar
              Balsa
              Rohacell
              Herex
              That sure sounds yummy.
                Originally posted by JYHELI View Post
                Hawkeye,
                porksoda,
                Jonathan
                Crashed composite? Aiyo..
                @Jonathan, you getting one soon?
                  The joy of education!
                  Regards,
                  Xuen7
                  SELLING
                  2 x Brand New ThunderPower G6 Batteries 65C 5000mAH
                  Kontronik HeliJive 120HV ESC
                  Brand New Mcpx Upgrades
                  Flashed XP-12A for MCPX Governed and Brushless Conversion
                  Flashed XP-3A for MCPX tail brushless Conversion
                  BUYING
                  MCPX parts / kit etc..
                  Burned MCPX Mainboards
                  "Learning the art of forgetting for the sake of remembering"
                    Jonathan
                    Hi Jonathan,
                    The wing for E-wasp and Eagle 5 is made up of glass-balsa-glass with carbon reinforcement along the wing spar.
                      Originally posted by Pang View Post
                      Hi Jonathan,
                      Thanks Pang... good to hear from you.
                        Hawkeye,
                        porksoda,
                        Jonathan
                        Was thinking abt buying that too, waitin for the answer but it never came. Hawkeye seems drifted a little.
                          As to which materials, Pang is in a better position to answer that question which he did.
                            Any one got a spare to let go ?
                            Now need ot get one for the long weekend..
                              Hi Jonathan,
                              Pang,
                              Is E-Typhoon make of the same material ?
                              Jonathan
