DLG Aero-towing using the "Velcro method"
Originally posted by sherchoo View Postpixeldixel,
When is normally your DLG session at OHR?Irony = displaying enough parking coupons on your dashboard but getting fined for littering when you throw the stubs on the floor
Originally posted by rt9 View Posteh..
how come the tow pilot became the dlg pilot at the end ah? :p
they swapped "seats" while the camera was aimed at the skyIrony = displaying enough parking coupons on your dashboard but getting fined for littering when you throw the stubs on the floor
Aerotowing is a really fun thing to do, although a little challenging. Velcro method is the easiest way to setup for aerotowing. However, it is does not have very positive way to stay attached and be detached. To prevent premature release, try not to let the glider fly too high above the tug. However, if the tug plane climbs too steeply above the glider and slows down, it can lead the glider to a stall, which is very dangerous for both planes.
To release the glider positively, it'll be easier to put the tug plane into a shallow dive and pick up some additional airspeed. Once airspeed is increased, the glider pilot just need to pull up elevator to seperate the velcro. Having said that, saying is easier than done. Recently, I did aerotowing with my students with a foam flying wing. The velcro used apparently is too strong and the flying wing glider refuse to detach from the tow line even after a shallow dive. When I put the tug into a steeper dive, the next thing that happened was that the flying wing literally blew itself apart in the air. It's quite funny to see a 80 gram foam wing turned into confetti though.
Originally posted by joe yap View PostAerotowing is a really fun thing to do, although a little challenging. Velcro method is the easiest way to setup for aerotowing. However, it is does not have very positive way to stay attached and be detached. To prevent premature release, try not to let the glider fly too high above the tug. However, if the tug plane climbs too steeply above the glider and slows down, it can lead the glider to a stall, which is very dangerous for both planes.
In the video, Ronnie?s Blaster got prematurely released because he had forgotten to tape his nose cone to the fuse. We have had a number of successful releases (when the nose cone was taped of course) when the dlg pilot abruptly pulls up when there is enough airspeed.
In order to ease the release process, I guess it also depends on the amount of overlap you give on the Velcro surfaces. We found that an overlap of about 1cm X 1.5cm to 2cm was quite ideal ? where the bond was strong enough to tug the plane along; but yet allows for an easier separation. However, there were some occasions where we experienced prematurely releases due to sudden jerking of the line (especially during the launch). In addition, to aid the separation, a ?pyramid looking thing? (for the lack of a better term) was used to help keep the tow line in place as the glider pulls up. I saw a video of some guys using a shuttle cork for that purpose when using the Velcro method to tow an easy glider.
