Threw together this 36" span FF DLG in two nights. I converted it to R/C using the Spektrum 6400 brick (same as Vapor brick).
Covered wing and tail in Japanese tissue applied using 1/2 strength Klear floor polish.Fuse boom is a recycled section of a fly rod that I broke when I fell into a pit while fishing in New Zealand. Was very lucky to walk away with only a broken fishing rod.
Hinges on tail group are the old over and under style using lightweight silkspan.
Had to improvise on the fuse pod. Used 1/32' ply for one side (the side that the brick is taped to and 1/64" ply for the other. Made wing removable for ease of transport.
AUW is 105 gms. Plan says target wt is 85 gms. So not too bad considering the limited wood selection here in Singapore and that she is now R/C.
Plan is here:
Took her out last Sunday and was quite pleased. Launches straight as an arrow and no problems with control.
Had one short session and then one servo the brick failed when I plugged in battery for another go. Smelled something fry. Gotta return it.
-David-
Plan is here:
-David-
