In Dec I bought a Caraway Glider kit from our local Singapore Hobby Supplies. The Caraway is a very reasonably priced glider kit that looks pretty good too. It's 1.4 m span and V-tail.
The purpose of posting this is to encourage this building aspect of the hobby.
1) It is not as difficult as you think but
It is another part of the hobby. If you like building plastic model airplanes, you might find the actions of breaking parts out of the sprue and fitting them together quite familiar.
The things you need;
1) white glue and CA glue
2) pins
3) a big, flat piece of blue foam to put your plan on
4) some wax or rice paper to protect your plan
So, first step, take out parts from the wood template - and then fit together using white glue. Pilot model kits are really good in that they fit together like a jigsaw. Pin together and wait to dry.
Thread the servo extension through.
Fit top panels together, then glue on. You may need to compress them with weights to ensure the top panel sticks. I use old magazines.
to be continued....
2) pins
to be continued....
