Actually looking at the span, the plane is quite small!
For speed you will need a high pitch prop but problem is that it is rather difficult to get small small folders with hi pitch.
What motor do you have in mind? I'm not too sure how many cells you can squeeze in there.
not recommended for normal flying... i believe this little fellow is design for speed .. heheheheh
if you wan to try your luck on speed little bird try the align speed glider..
cheap and very fast!!!!
Fuse,
I am interested in this bird too, especially your Mega on 4.7 setup. Any chance you can get a video of speed flyby soon, I can analyse your speed and see how fast it can go. Should be super duper.
Hans
Thanks for the infos but been to Waigo before NO Chilli or Mini Ventus.
Will PM you once I have flight confirmation.
HK-Kwong Wah area is more for cars than plane.
