Bandit is a 1.4m Mini Hot-liner that can be flown on the slope or on a flat field. It is fast and highly manoeuverable, but will also make good use of thermal lift.
The epoxy fibreglass fuselage is complete; you only have to instal your power and radio equipment, and add a canopy retainer.
The wing is in two pieces. It is moulded from foam and veneered with obechi. It is also strengthened with fibreglass cloth. The wing servo holes are machined, and the the ailerons are cut and hinged. The tips are moulded into a slightly up-swept shape which improves both the appearance and the performance. The wings are completely finished and covered in Orocover.
This aircraft makes an ideal high performance electric model using 480 or 500 size motors. Brushless motors provide vertical climbs at heart-stopping speed and sparkling performance.
