After watching Johnson fly his scratch build KF glider, I was impressed by the simplicity and the reasonably good performance of the glider.
The wing is just 2 pieces of 6mm depron foam, strengthened by 0.5mmx5mm carbon strip. The fuselage was built-up as I proceed. Just got a set of 8x4 folding prop from JH and 2s DN battery.
With the little time that I have between waking up early and sleeping late, I am now about 70% done with this glider.
Here are the plans and some pictures. I should be posting more pictures with report when I am nearer to completion.
MS
(the PDF plan is too large, you may want to download from here:
MS
