Hi All,
Just like to seek opinion on the brushless upgrade for Easyglider from the folks who have already done that.
Am eyeing the Multiplex BL400 8D brushless motor at NTC but apparently it is 3.2mm shaft diameter whereas the stock motor is 2.3mm with pinion sized for that. Not sure if I can find a suitable pinion of 3.2mm for the BL400 8D if I get it through NTC or if the stock gearbox can fit with a 3.2mmm shaft.
Has anyone successfully found a suitable pinion or has installed a BL400 8D 3.2mm with the stock gearbox?
Thanks!
Thanks!
