TT MT4 G3 no power
    TT MT4 G3 no power
    Hello racers
    Need your help
    there seems to be no power at all to the wheels
    I have changed the central diff with new one and the wheel rotates without any issues when not on ground but as soon as it is on ground it does not go forward
    Please help Thanks
    https://www.youtube.com/watch?v=ZnShwtkrdiI
    Check the gearbox. It might be the gearbox problem. Something is loose somewhere and no in touch
      check battery connections
        do you filled the gearbox with differential oil???
        I love PAP
          Any chance any grub screws are not tightened or pinion or gears are not assembled properly?
            [QUOTE=anandpal;631620]Hello racers
            Need your help
            Please help Thanks
            **Check the central diff again, it might be in the wrong direction(just like a one way ball bearing).
