ANy recommended servo??
    Any recommended servos for 1/8 buggy.Low $$ and gd??? Thanks.
    C&G, but just enough. Hitec HS625 for throttle and HS645 for steering.
      Using it for my 1/8 buggy and 1/10 mtr truck..I am considerin the hitec hs-645Mg....isit good ??cos the torque is abt where i req...
        C & G???
          C & G???
          cheap and good lah. and yes, i think good enuff, use to use it on my MT and buggies
          Go Track Repair Car...Dun Call Me
          Go Track Talk Also...Dun Call Me
          Go Track Play Car...Can Call Me :na
            wonder if anyone selling used ones...hehehe
              that you go marketplace and ask man, here sure no one see it
                or mayb can check out at winnie if she selling this...
                  posted liao...Thanks !!
                    dun bother, only rotor
                      Not really recommended for throttle (Slow response 0.23@6v). Use for steering.
                      Get something better for throttle (At least 0.12@6v). At least a 925 will be good. VB, ZB, VX etc are the best.
                      Suck Squeeze Bang Blow
                      20,000 times a min
                        for buggies,the only servos best for buggies would be,
                        sanwa VB servos for steering and
                        sanwa VR servos for throttle.
                        it will last years. .
                        enjoy.
                        Sondol first talk later!
                          It's 'good enough' with 9.6kg/s at 6V. Up to you to decide. Want more torque, a bit more ex. Then can go for HS945 (10.6kg/s @ 6V), HS-6985 (12.4kg/s 2 6V) or big mutha HSC5955TG (24kg/s @ 6V)!
                            Hi ofna.why would you need a high torque servo for the throttle? These standard servo should be sufficient right?
                              You will suffer with the standard servo on the buggies.
                              First the throttle cannot close properly due to the insufficient torque to return center. Next, it will not have enough torque to pull the brake.
                              When you get a high torque servo, get a high speed one. 645MG is slow. When the bug is in the air, the response time is slow(when the buggy is nose down, you can't bring it up fast enough), you can't handle it as well as a fast throttle.
                              Go for the Sanwa VBs' and Vxs'. They are the best money can get you. Hitecs are good for planes, but on buggies, they dun perform as well.... They tend to lose centering.
                              20,000 times a min
