Bent chasis
    Bent chasis
    If I bend the bottom plate of the chasis back will it be as strong as before? I crashed and the whole bottom plate bent.
    That must be a bad crash.Monster truck??
      V one S 3mm chasis not very strong. can bend with bare hands. get a 5mm one GPM
      Sanwa M8 Version 3
      Kyosho Inferno777 SP2 WC/STS21D
        Neo how u noe I using vone s2? ok I try bend with my hand. the 5mm gpm one how much? I got to asiatees cannot find.
          first u play with tt01 . then wanna sell . now u got v one s 2 leh . he he . your post i got see leh. wanna play together with my superten ?
          Sanwa M8 Version 3
            Gpm?
            hiya Haowee!
            hhmm, i've never had a fabulous experience with GPM products although ima sure many others have used them successfully.
            my personal opinion is that the aluminium alloy GPM uses is kinda weak.
            if you have to get a new chassis, why dunt you consider one from 3racing, kawahara, Eagle racing(which is basically K-factory) Five star or K-factory(my personal fav)?
            i have used a 4mm v1r chassis without tweaking or bending...
            have fun!
            -alexander
              u can use a bench vice to bend it straight. if too thick, hard to bend back . 3mm chasis is ok.
              Sanwa M8 Version 3
                Where to buy all those parts? I trie to bend back with my hands looks ok now. But some corners still not flat on the floor.
                  can try hobby place,toykar or HB to see there is a 5mm chasis
                  Sanwa M8 Version 3
                    clamp it using a huge vise clamp
                    should bent it right back.
                    Branden born on 8th Oct 2004
                    Vivian born on 21st Oct 2006
                    [IMGhttp://www.anchoredbygrace.com/smileys/baby2.gif[/IMG]
                    Honey Bee T bought on 15/9/05
                    Broke tail blade on 18/9/05
                    Broke tail blade shaft 23/10/05
                      I would advise u to use a new one. Once the Chassis is bent. All kinds of alingement problems going to creep up.
                      One day... one day...
