Help
    Help
    Help,My crystal broke in my receiver.1 of its leg is stuck inside.any idea how to remove it?
    Plane 1:
    FreeWing F-15
    Plane 2:
    GWS Blue Angels C-130 (EDF)
    remove the screw from the rx case and use a long nose plier to pull out the stuck pin.....
        omg.hard work
        Plane 1:
        FreeWing F-15
        Plane 2:
          jialat,its stuck all the way in.can desolder and remove?
          Plane 1:
          FreeWing F-15
          Plane 2:
            Originally posted by hoppie
            err...did i say anything wrong??
              dun think it can stuck all the way leh..its basically a whole where the pin is/take a mini screwdriver or those needle and push trough the hole(rx circuit board)...open the case first.
                open liao.the pin is in de hole
                Plane 1:
                FreeWing F-15
                Plane 2:
                  well..reverse the circuit board and poke through the hole where the pin is??
                    cannot oso .jialat.tink time for new rx.haha
                    Plane 1:
                    FreeWing F-15
                    Plane 2:
                      use the solidering iron to heat up the holder and use the tip of the pen knife (or pincer) to get it out
                        cant.try liao.theres only 1 hole leh.
                        Plane 1:
                        FreeWing F-15
                        Plane 2:
                          maybe u can post a pic? so we can help to think of something?
                          garage:
                          E-savage basher
                          TLT-1 rock buster
                          TT-01R/D
                          area: jurong, any kakis?
                            Hi, I think it a close end pot for the crystal to plug in. Unless the leg is still long enough to be pull out by a plier, You could be losing a port. If you can solder and is good at it, take a walk at simlim tower. Try to find a replacement port and get it de-solder and replace. Worst case, a new receiver.
