Need advise on steering servo for 1/8 off-road car
    is futaba 3001/3003 good enough to use as steering servo for 1/8 off-road car?
    u need at least a 13kg servo, unless u dun mind change servo every now and then...3001/3003 is use for on road....
    DJI II | Futaba D8FG
    HPI BAJA | ESP Fully Championship Ported 30.5cc | OBR 7HP | 4PKS
      No.
      f
        thk
        In that the case, can i use it as throttle servo instead?
          any advise which servo made/model to get for use as sterring servo? Cause futaba servo didn't seen to have one that can handler 13kg.. (too x already if there is..)
            Tower Pro MG945
            13kg
            $30?
            TREX 500 ESP
            Futaba T12FGH
              ok. Thanks Art
              now.. on hunt for this servo
                the ******** shop got
                TREX 500 ESP
                Futaba T12FGH
                  nvr.. will try to check Jet and sky is they also carry it or not
                    i'm using sanwa VR 8kg for my buggy steering for 5 race least of 40mins main and pre-race pactise day.
                    This servo is awsome and cheap
                    1/10 On Road
                    Kyosho VoneRRR-EvoWC
                    1/8 Off-Road
                    Kyosho MP9
                    Member of EDMW plus NPNT
                    เวลาช่วยรักษาแผลใจ
                    กับผมแล้วผมเห็นว่าเราชะนะแน่
                      is the tower pro MG995 able to use for steering? Or MG945 better choice?
                      Btw, any1 can advise me where can get the sanwa V* series servo that have better holding for seavage? and extimate price?
                      thanks
                        thanks
                        Hi I am using the MG995 on the esavage. The stock servo simply cannot make it.
                        The MG995 is alot stronger than the stock servo. The speed should be enough for u unless U wanna make very fast and sharp turns..... that is if your truck wun topple over at the kind of speed that it is capable of.
                        Esky Dauphin
                        Walkera Lama 2
                        Walkera 5G6
                        Brushless Micro-T
                          BUt do take note that the servo will overshoot or oscilate at every position.
                          It can be still used for trucks though.
                          Esky Dauphin
                          Walkera Lama 2
                          Walkera 5G6
                          Brushless Micro-T
                            Hmmm... Did some research and found that the digi 4 range of servos by multiplex seems to have very good specs at good prices (cheaper than futaba or sanwa about 25% less for similar specs).
                            How are mutliplex servos like? Reliable or not? Any known problems to multiplex servos?
                            Esky Dauphin
                            Walkera Lama 2
                            Walkera 5G6
                            Brushless Micro-T
                              thk LittleGiant, i intend to use this 995 for Savage also
                              so far most ppl advise is use the sanwa VR ot VX for the steering.. saying is good and cheap.. but both range at >$150
