Originally posted by gijjarg
New Cat
Side X Side, would be ideal having a lower CG. Set-up will work.
"The 40/160 is definitely under-rated at only 160 amps cause I have spiked mine well past the 250 amp mark on 10 cell setups and doubt you will have any issues with it ... I have used the 40/160 on 12 cells with my 3080 powered Apache but that is a lower Amp draw setup." (Punisher67, OSE)
2013 RC4WD International Team Driver
Originally posted by Adrianli View PostU might want to consider putting a metal plate between the two ESC. If one goes up in flames, at least it will not affect the other. Having both up in flames will really make u2013 RC4WD International Team Driver
