A power driven vessel when towing must show
two masthead lights on top of each other, instead of the masthead(s) prescribed in Rule 23;
sidelights;
a sternlight;
a towing light vertically above the sternlight;
a diamond shape if the tow is longer than 200 metres (656 ft).
if a pushing vessel and the vessel it is pushing are rigidly connected, they count together as a power driven vessel and must show the light prescribed by Rule 23.
If the pushing vessel and vessel being pushed are not rigidly connected, they must instead show:
sidelights;
a sternlight.
Power driven vessels larger than 50 metres (164 ft) which are towing or pushing and are not part of a composite unit must also show:
a second masthead abaft of and higher than the forward one (vessels smaller than 50 metres may also show this light).
Vessels being towed that are not inconspicuous or partly submerged must show:
sidelights;
a sternlight;
Any number of vessels being towed or pushed together shall be lit as one vessel, and
a vessel being pushed ahead must show sidelights at its forward end if it is not part of a composite unit;
a vessel being towed alongside must show a sternlight and sidelights at its forward end.
A vessel being towed that are inconspicuous or partly submerged must show:
if it is narrower than 25 metres (82 ft), one all-round white light near the forward end (except if it is a dracone) and one near the after end;
if it is wider than 25 metres (82 ft), then also two all round white lights at the extremities of its breadth;
if it is longer than 100 metres (328 ft), then in a series of such all round white lights spaced no further than 100 metres (328 ft) apart;
a diamond shape near the end of the last vessel, and, if the tow is longer than 200 metres (656 ft), another diamond shape as far forward as possible.
If for any reason it is not possible to light the vessel according to these rules, all possible measures must be taken to light the vessel and indicate its presence.
If the towing vessel is not normally engaged in towing operations and it is impractical to light it correctly, it is not obliged to show these lights if it is towing a vessel in distress or in need of assistance. All possible measures must be taken to show that it is towing; in particular the towline should be illuminated.
So how long it is going to take?I am really excited to see the progress on your boat.I also once tried to make a boat but didn't succeed in my work.
Hi bro. tks for the interest, but I am still trying to figure out the electronics and other stuffs. Most of the stuffs need to be scratch built so it's taking time.
One major setback to the build is that I broke the Pilot house while sanding it down. Now will have to re do the whole thing again. This time will use different method & material so that I don’t have to do any sanding.
sidelights;
a sternlight;
sidelights;
a sternlight.
sidelights;
a sternlight;
I was not too happy with my earlier structure and decided to redo the whole thing over again. But this time I've used styrene extensively with wooden bracings. I also did my 1st brass railings, I've never soldered anything before, this was the 1st time.
Btw, you can see the amount of materials I've managed to waste, trying to improve my cuttings skills.
