Hi all, i'm new to RC Sailing and this is the first boat i've built.
I noticed that the main sheet (the main sail control line) tends to get entangled easily in the winch servo drum. This happens when you sheet out too much, there is excessive slack in the line and when you sheet back in, the line may get entangled below the servo drum, where the servo axle is.
Is there anyway to counter it?
I want to put the plastic cover over the winch drum but its a too tight fit. The winch drum cannot rotate under the plastic cover. I've bought some fishing line weights which i'm going to attach to the main sheet and the jib sheet, and experiment to see if it can weigh down the excess slack. But i think that this will reduce the sailing performance, like for the sail to luff up in light winds.
What do you guys advise?
Thanks in advance!
Terry
Thanks in advance!
Terry
Cap21,
Elster,
Jazz60,
SouthernX,
Zoom 4D
