Just less than a week since I lost the old one, I'm already missing it. I'd already cleared up the table and now starting on the new one. These are what I've been cutting for the last few days. Now, I have enough parts to start off the fuselage construction.
The new Dash-8
Originally posted by WishHi Master Yap,
May I know how you cut those Balsa?
Thanks!
Originally posted by joe yapThe outer diameter of the round formers are cut using penknife and steel ruler as guide. Instead of cutting curves, I cut multiple facets until the rough round shape is formed. Sanding block gives the final smooth curves. The lightening holes are bore out from a round brass tube with one end sharpened. Each formers are cut from 2 lamination of balsa sheet with cross grain. This makes them stiff.
Thanks.
This is a little different from the previous one. Instead of building seperately, I built these 2 sections with a comman keel beam. As you can see from the picture, I made a jig to produce the tail bottom profile. Even with this jig, I still incorporate an intercostal over the keel beam to keep in shape. There goes the same for the spine. Without them, there'll be a chance that entire tail section will spring back and distort the whole structure.
