Hello people, i'll be getting a formosa soon, 2nd though, but intend to break it up and rebuilt and re-enforce the plane. Can anybody with the experience tell me which of these are neccessary or would like to add more pointers to it ?
1) Glassing the formosa. I've read the glassing thread, and it seems that glassing the plane will strength it and give a smoother flight at high speeds. Is this neccessary ?
2) Read on RR that you should have individual servos for the alieron, making 4 servos for the formosa. Is this needed ? I'm also aware that with individual servos, you can use 'flaps', which is suppose to be better for landing ?
3) Carbon fibre rods are used instead of the stock ones they give. Any other things i should change other then this ?
4) What motor should I be using ? I'm intending to use a AXI 2212/26, can this be used as a direct drive or I still need gearbox. Some people in the RR used the HIMAX 2025/4200 with some gearing, which is more preferred ? I'm planning to use a 33A esc or is a 25 AMPS one good enough ? Lipos intended is either the etecs 1700 or the 1900. Or is the 1250 good enough ? Btw, 3S1P
5) Any other things I should take note or you experienced formosians have some tips to share ? I'm aware that the front of the formosa tends to break easily, is there a way to protect it like ... making a plastic mould for it ?
