I bought my 1mm clear PVC sheets from the shop beside Jet Hobby in Fook Hai Building. For white PVC, I bought mine from Art Friend in Bras Basah complex.
de Havilland Canada Dash-8 construction
Landing gears are mounted in place. The nose gear has its steering linkages connected to the rudder servo. I modified the Dubro landing gear axle fittings for tandem wheels. The original wheels are foam tires with aluminium hubs. These have hardly any shock absorbing effect on landings and were later replaced with Dubro rubber wheels.
With the nacelle-to-wings fairings in place, the entire airframe structure is certified completed. With all equipment and powerplant installed, this bird is ready to take-off at 3.4kg AUW.
Vital Specs are as follows:
Span : 79"
Wing area : ~ 620 sqin
Airfoil : Douglas LA203A
Fuselage length : 58"
All Up Weight : 3.4kg
Powerplant : 2 x Permax 600, 2.9:1 gearbox and 10x8 MA prop
Battery : 10x3300 nimh / 10x3700nimh
