The other time I drill out w 2.2mm bit then went thru w a 2.3mm so that the pinion can go w a Hacker brushless
Mike
thanks mike. found the 2.3mm gws pinion gear at jethobby. it fits real good so you can try some from jethobby next time you need them. however, got a problem, my bench clamp is too small to fit the motor and pinion gear inorder to get it to slowly fit into the shaft. any idea where can get bigger bench clamp?
