Anybody knows where to buy foam to do scratch build please tell me. Btw looking for buddies to fly with me behind Christ church secondary woodlands
Where to buy foam
Depending on what plane you want to build, but for depron, I personally think the depron from artfriend (6mm) is much stiffer, easier to cut and also any tape can stick to it with no problems...the depron from jet hobby (5mm) is much harder to cut as it is soft also tape don't stick on it that well. Bluefoam from jet and artfriend is equally good. Personally, I go to artfriend when buying any foam as they have a larger variety.
Originally posted by Janson View PostDepending on what plane you want to build, but for depron, I personally think the depron from artfriend (6mm) is much stiffer, easier to cut and also any tape can stick to it with no problems...the depron from jet hobby (5mm) is much harder to cut as it is soft also tape don't stick on it that well. Bluefoam from jet and artfriend is equally good. Personally, I go to artfriend when buying any foam as they have a larger variety.
Also, bras basah art friend seems to have more variety than takashimaya art friend.
I do not know about other branches.
There's another artfriend branch at bouna vista. I think its the most convenient one since its located in the Mrt station, no need to walk far far. Also they have quite alot of foam varieties. But if its epp you are after, theres no choice but to go jethobby. I dont think can get epp anywhere else in sgp...or is there?
Was just browsing throught the jet hobby website but found that they do not carry foam of 9mm online. http://www.jethobby.com.sg/cgi-bin/e...9&idx=1&gid=16 Anyone knows if they have 9mm foam in store?
Originally posted by boonyeo View PostU can buy the depron foam at (zone5hobby) Fook Hai Building or any of the shop there
Depending on the depron foam you want from 3mm,maybe they have 9mm depron foam ........
Originally posted by perdification View PostThanks for reply bro. I'm looking specifically from 9mm depron since the plans require it. Would be a pain to have to glue different foam thickness together...
Originally posted by rayonnair View PostI bought 9mm depron from the art friend at bras basah. Hunt around the shelves - some of them will be paper covered, some will not, you will probably want the one without the paper covering.
