I am looking to make a rc plane for a school project. The main aspect of the project is not flying it however it would be nice to build it and then be able to fly. I am thinking of having:
Velocity Power (SD1300-3-30, 11.1V, 30C) battery to power the whole thing
SKYWALKER 40A Brushless ESC
SUNNYSKY X2212-1400KV Outrunner Brushless Motor (11V, 12.4A)
EPP foam
3 Servos (Rudder, Aileron, Elevator)
1200cm^2 wing area
246cm^2 stabaliser area
60cm Fusalage Length
Firstly do you think this would work (ie fly)? And i am not sure which servo's i would need ie micro or metal and torque required? I know i will need voltage regualtors for this. Also i am not sure what thickness of foam to get 5mm or 10mm?
Any other helpful comments also welcomed.
Thanks
EPP foam
1200cm^2 wing area
Thanks
