Hi bros any idea if the zero fighter can fit a 1350kv turnigy motor?
FMS Mini Zero Fighter
It's convenient to use those "mushroom" type outrunner motor design with a round motor mount. Is your Turnigy motor of this type?
You can then just use the existing motor mount already fixed on the Zero's firewall, then tighten two set screws to secure the motor.
Perfect drop-in replacement with minimum fuss.
I think the KV you mentioned should be okay. I'm using 1500 kV with APC 7x6 twin-bladed prop on 3S for a Mini T-28, and she's fast!! Be careful of changes in CG though, due to differences in motor weight.------------------------------
