Hi guys.. Does anybody know how do I gain more altitude even though i've pushed the rudder stick on my tx to the fullest? Do I need to upgrade to a better motor or prop to achieve better altitude?
Gaining altitude on sky surfer
You don't use elevator to climb. Airplanes climb with power. There's always a tendency for a novice to over control a model. As long as the model is flying straight and level, advance the throttle stick and let the plane do its job. Putting too much up elevator will only add drag to it. Also, check that the cg is correct.
