Hi guys , today when i tried to fly my kinect800 , it just go up abt 1 meter up and away then nosedived onto the ground . I was told to use 50% throttle by the seller but i thought i want to see if abt 3/4 throttle will work anot cos i thought at the most the plane will just glide to the ground and i did tried to give it some elevator when it nosedived to see if i can make it fly up anot . But prove i was dead wrong , it just dived to the ground ending with its broken nose full of " shit " . I already glued it back , letting the glue set for a day or more depend on my free time . I already checked the cg before i throw it out so i don't understand how it can nosedive instead of gliding down to the ground .
So i just want to know if its because of the reduced throttle that cause it to crash or is it because i didn't throw it hard enough , or will the propeller which is very slightly pointing downward due to an earlier repair will cause it to fly downward .
I just want to know what did i do wrong , cos i really like this plane as it is small enough to be flown freely at smaller fields .
