Hey guys,..was just reading up on P40 Warhawk and it said it was one of the tightest-turning monoplane fighters of the war, although at lower speeds it could not out-turn the extremely maneuverable Japanese fighters such as the A6M Zero ..so anyone with that FMS zero...can confirm that? i.e. is the FMS zero "extremely maneuverable" at lower speed? Thanks!
P40 vs ASM Zero
If you're referring to the 800mm FMS Zero, I can confirm that it is extremely stallable at low speed [laugh]
It is quite prone to vicious, sudden wing tip stall that can cause it to corkscrew or spin suddenly.
But maneuverability... beats the Trojan 800mm - I've flown both and these are the only two I can compare.------------------------------
Originally posted by foxkilo View PostIf you're referring to the 800mm FMS Zero, I can confirm that it is extremely stallable at low speed [laugh]
