Those of you who bought the FMS T28 1400mm (Big Warbird), please let me know if you like it and what's your setup? Are you able to hand launch it? Where do you fly?
Anyone own the FMS T28 1400mm (Big Warbird)?
This topic is closed.
Originally posted by goot View PostThose of you who bought the FMS T28 1400mm (Big Warbird), please let me know if you like it and what's your setup? Are you able to hand launch it? Where do you fly?
It should be powered by a 4s battery, and size should be between 3000 and 4000 mah, with the lower size battery to be pushed forward to get the right CG.
This is a really nice warbird and it flies beautifully, even at half throttle. Just watch the landing, you need some throttle on touchdown or the plane will come down heavily, and you might damage the landing gear.
Takeoff at full power with flaps down should take between 5 to 6m, but it can takeoff even on short grass, as long as the ground is level.Beastx installed and flying ...
[SIGPIC][/SIGPIC]
Originally posted by kiply View PostHi and erm .. you cannot handlaunch this warbird because it is big. Anyway it has retractable landing gear so really takeoff and landing should be on the ground.
Hi Kiply, Thanks for sharing! Where do you fly this warbird since you can't handlaunch it? I usually fly at Tampines but can't find a place to take off except for the road which is quite dangerous due to the trailer and the trees plus cars. Great to hear that it can take off from the grass though.
Did you get the kit or the PNP version? I'm thinking of getting the red/white version as the silver one looks pretty hard to see in the sky I feel.
Originally posted by goot View PostHi Kiply, Thanks for sharing! Where do you fly this warbird since you can't handlaunch it? I usually fly at Tampines but can't find a place to take off except for the road which is quite dangerous due to the trailer and the trees plus cars. Great to hear that it can take off from the grass though.
Previous poster questioned why the need for 4s. Seriously for me, I just follow the recommended specs, and since I have the 4s batteries, it doesn't hurt But you can try with 3s if you want. This is a heavy plane , so I think its always better to have a bit more power to be on the safe side.
Please kindly stay off the pavements for take offs at Tampines, there's simply too many public activity there. As long as the grass is short and the ground level, you can take off and land from the field.
I got the PnP version, the electronics are sufficient. Bear in mind though this plane uses 12 servos I think, not to mention 5 LEDs. The kiasu side of me insists on using a BEC.Beastx installed and flying ...
[SIGPIC][/SIGPIC]
Originally posted by kiply View PostI fly this plane at Tuas, where there plenty open spaces to go full speed, and the pavements make excellent runways. But sometimes the cross winds can be a killer, so need to be careful.
Which part of Tuas do you fly?
Originally posted by Caine View PostWhy do u need a 4S setup for the FMS 1.4M warbird? Lanyu 1.4M F4U only requires a 3S setup...more servos for the FMS verson?
The Lanyu flyies slowly with stock setup. I changed the ESC and use 4S to get good speed.
Originally posted by gpsnuts View PostThe Lanyu 1.4M F4U uses 810kv motor, The FMS 1.4M war birds use either 500kv or 600kv motor.
High KV does not always mean high power although it does mean high rpm per volt.
The stock setup of the Lanyu big bird use 30A ESC. The measured input current is about 28A when use with fully charged 3S battery. When I switched to 60A ESC. I can get 35A of current draw from the 3S battery. The peak rpm also goes up. This means the stock ESC is not supplying enough current to the motor. When I plug in the 4S battery, the peak current is 45A.
So far, I played with only the ESC and the battery.
Caution: I do not think the stock ESC is capable of 4S.
Ah ok, but I feel that's a little strange that the stock ESC kind of limits the max current drawn somewhat. I do understand that the rating of the ESC means allowable continuous current drawn.
Back to this big warbird, how heavy is it full loaded with a 3000mAH 4S? How do you guys transport this bird - can you remove the wings prior and place it in the boot? Can it fit into an MPV with wings attached?
Originally posted by gpsnuts View PostHigh KV does not always mean high power although it does mean high rpm per volt.
