Having a H Hub lying around, and the spinner cost as much as a new one, its crazy to buy one, so I decided to make one from ply wood.
The idea is to cut 9 pcs of ply wood of varying radius and stick them together and shape out.
The disc are then epozy together and tapered down.
Next is to cut the slot for the H hub to sit in and drill the 2 holes to lock down the H Hub to the ply spinner.
Then test fit the H hub. everything looks good.
Drill 2 holes to access the grub screw in the H hub
Done!
Test spin the assembly at 12,000 rpm shows no vibration at all
The remaining nose cone will be made of balsa and shaped down. I chose Balsa to keep the weight down as full ply is quite heavy.
Done!
