Hi all, have been facing problems with my pusher prop gliders recently. For my skysurfer, once i added the LED strips on the plane, the plane tends to roll left when the motor runs, I have a feeling that the LED strip that is running across the top front of the wing is the culprit. While my other plane, eaglewing, tends to also roll left. I noticed the wing tip on the right side of the plane is bent up more than the wing tip on the left side of the plane. Anyone faced these problems before?
Pusher prop glider
The turn to the left under power is a normal occurrence in all planes with right hand props due to, depending on who you ask, p factor, torque, gyroscopic procession and/or the spiral slipstream. The aerodynamicists out there can explain this better than I ( and confuse the heck out of you with their arguments- I don't think this whole idea of exactly what's going on when things fly is completely sorted yet) but just know that a force exists, especially at high angles of attack, that wants to turn your plane left. Can counter this with a rightward (and downward, to reduce relative AOA of prop blades) thrust angle and readiness with the rudder stick. Watch a taildragger light plane take off and see the kicks of right rudder needed to keep it straight.
Here's a thread regarding this:http://www.rcgroups.com/forums/showthread.php?t=970004
Sorry, perhaps I misunderstood. You said the planes tend to roll left under power. That's the common effect I was describing.
Check to make sure that the right wing tip is not twisted up. This is called wash-in. You should correct this and try to get both tips the same. I'm not familiar with these planes but perhaps hot water and opposite twisting should help. The right wing tip having wash-in will definitely cause plane to roll left. Worse, this condition can easily cause a tip stall, which will dump the plane suddenly to the right. This will happen when you're low and slow and a crash will be the result.
This might also mean that the left wing is heavier than the right?Originally posted by shoyn View PostThank you for the link. But the last time i flew these two planes, both planes do not tend to turn in any direction when gliding."Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
Originally posted by Deedubya View PostSorry, perhaps I misunderstood. You said the planes tend to roll left under power. That's the common effect I was describing.
How do you know that both tips are the same? I think this could be the problem i am facing.
