Hi there, does anyone have a recommendation for a 3S setup on a funjet ultra? Not looking for a crazy speed machine. Would a 2900 kv motor with a 3S 2200 be doable on a 6 by 4 prop?
Funjet Ultra 3S setup
Originally posted by benjychan View PostHi there, does anyone have a recommendation for a 3S setup on a funjet ultra? Not looking for a crazy speed machine. Would a 2900 kv motor with a 3S 2200 be doable on a 6 by 4 prop?
i just completed my flight test on both the light and heavy setup.
light setup
a. 60 amp esc
b. 4.75 x 4.75 apc prop
c. 4s 1800 mah
d. motor topband 3900kv
good for easy flying around. full throttle on launch
heavy setp
a. min 80 amp esc
b 6x3 prop.. still testing so will upsize only later
c. 5s 2450 mah
d. turnigy 1450 kv
faster....in my first atte,pt, i was worried too much about torque roll and did it punch it..gave it 40 percent and that did me in as the plane cannot take off and hit the ground hard.
repaired it and today i gave it 70 percent... worked well....
the ultra really needs the umph on take off.... not able to control without the umph....
Originally posted by benjychan View PostWould it be more beneficial to step it up to 4S for a lower amp draw?
Originally posted by chessgame View Posti just completed my flight test on both the light and heavy setup.
FAST and FAST(ER)"Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
Hi, need help.
Was flying my heavy setup today.
heavy setp
a. 80 amp esc
c. 5s 2450 mah
d. turnigy 1450 kv
Everything ok until 3rd battery. Motor suddenly seized up and had to do a dead stick landing.
Came home, checked the motor, cant seem to find anything wrong.
Now when i throttle up above half throttle, motor twitches and stalls. Cannnot reach full throttle now. Also becomes very hot when i start to power above half throttle.
Tried to change timing, and still have this problem.
Tried esc on different motor, and it seems ok
Any advice what happened ? Cant figure it out.
The other thing that you may wanna check is the bearings. By any chance you are able to measure the current?
If it's drawing too much current due to the extra load of the worn bearings, the ESC might shutdown due to overcurrent.
Originally posted by chessgame View Postlight setup
a. 60 amp esc
c. 4s 1800 mah
a.40A esc
b.5.5 x 4.5 apc pusher
C. 4s 2200mah
d. Top band 3450kv
This is already the smallest prop and the motor is stressed... my understanding is uping the esc to 60a wouldn't help to cool the setup? Is it?
your prop is too big . and yes a bigger esc will help in the sense that the esc can take it but your motor will still get burnt because of your prop.
if u using 5x4 prop onwards, suggest you get a lower kv motor ie 2450kv.
less speed, but nothing will get burnt.
but of course, nothing is stopping u to do more testing on the above .
beginners mistake
Following my hunch I took a 2nd look at the motor mount...
I was missing the c ring at the base of the motor shaft. Thus at speed the prop adapter was pushed against the mounting plate and the friction heat is the result of binding... changed the motor out to a scorpion 2221-8, 3595kv... the funjet lives! yum yum
