3 Prop vs 2 Prop
    3 Prop vs 2 Prop
    Did a bench test on a 10x6E prop vs a 8x6(3 bladed prop) and here are the findings:
    2 prop - 10x6E
    Full throttle, max amp = 13 A giving 150 W
    60% throttle, max amp = 5.2A giving 59 W
    3 prop - 8x6
    Full throttle, max amp = 11A giving 132 W
    60% throttle, max amp = 5.4A giving 61 W....or something like that,
    seems like they both perfrom about the same at half..or close to half throttle. BTW, in case some might ask, how are these 2 diff prop relevant to ea other, when you change from a 2 prop to 3 prop, normally u have to down size the prop for 3 bladed to prevent the motor from frying. Anyone has similar results on their test for diff prop?
    I think a 3 bladed prop gives you more thrust but lower top speed while the 2 bladed prop gives you less thrust but higher top speed.
      3 bladed vs 2 bladed
      whatabout 4 bladed prop..like mustang,.....must be really powerful
        Should be. But its at the expense of the plane's top speed. Some people used 3-bladed or 4- bladed prop for scaled appearance.
