I just bought a mini chong merlin from Jet Hobby for under $90, its ARF just need batt and Rx/Tx. The plane's wingspan is 13 cm shorter than Merlin and uses a 6A ESC so outdoor flying with gusty wind is a total failure. When you pull hard on the plane, it tends to flip and it flips easily, does not have strong motor, body compartment is super small, can barely fit my batt I used for Kinectic 800 which is a 450mAh 20C 11.1V. CG off balance, need to attach a AAA batttery near the tail end of the plane, on the other hand, the good news is that the crash kit is under $30. But for another $10, you could have Kinectic 800 delivered, conclusion, unless your living room is as big as an indoor stadium, forget about it.
. If you are a new flyer and have little knowledge setting up planes, go and seek help from regular flyers. Cheers
Just look at the price tags!!
