Red Eagle Model YeeBee
    Got a plane as attached. attached all servo to rx and try to align everything to centre.
    when try to fly the plane it always go toward the right try trimming on the rudder but have no use. any suggestion?
    J.S Carlos
    Hanger
    • Goblin 500
    • Copter X SE 480 - 3s HeliDrive 3600KV - Robird FBL
    • MSH Protos 500 Low Hub Stretched - Brain FBL
    • Spirex - TriCopter - Pcs of Crap Hanging on the Wall
    Tx
    • 8fgs
    • Devo7
    • Devo7e
    Maybe you have built in too much right thrust on the motor mount.That is look down on the motor and see which direction it is pointing my guess is that it is pointing to the right. Try putting some washers between the motor mount and the firewall on the right side. Good luck.
    Having fun yet?
    36.39mhz
    40.77mhz
      Hi.. Thank.. Sorry very newbie.. where to get the washer from.. how to put in on the right?
      J.S Carlos
      Hanger
      • Goblin 500
      Tx
      • 8fgs
      • Devo7
      • Devo7e
        hmmm
        actually if u got this plane 2nd hand then u should have ask the seller to explain a bit more for you. and honestly i dont think its a beginner plane to start with. try to ask seller some questions regarding the flying characteristic, cg location, battery size, prop size, etc. since u are beginner, all this might helps yr input.
        btw, as wat p&f says, add a washer behind the motor cross brace so that yr motor is pointing towards the left a bit more. if 1 washer is not enough, try using 2 till desired angle is achieved.
        Flying is all that matters...
