Simple small RC planes with Depron
    Hi, Just to share a simple creation using Depron, electronics from DWE and downloaded plans from RCgroups : the 14 inch wing span Daddy-O depron plane. It flew !! Up to 8-9 storey high on a calm early saturday morning.
    Sci_fighter,
    That's a really cute and tiny plane you got. Problem with planes this small is the equipment... How much did the equipment cost and where did you obtain them!?!?
      csisfun,
      bro, a plane that can fit in your bag!!!!
      go build one!!!! hehee..
      rifqi.
        This is a kick ass plane!
          Hi Csisfun. I bought the electronics online from Dynamics Unlimited formerly also known as DWE - Dynamics Web Enterprises. The plane has a 5.6g KP00 motor with a U80 propeller. The heart of the system is the tiny 2.1g RFFS100 receiver which has proportional throttle control, rudder and elevator servo controls. I am using only one magnetic coil servo (1.1g) to control the rudder. I could also add another magnetic coil servo to control the elevator which I did not do so.( Could add later on I guess ) The battery is a 5.8g 250 mAh LiPoly. So total flying weight 's about less than 30g. You might like to visit the web site www.slowfly.com for more details. Total cost : KPOO Motor+U80 prop ( USD19 ), RFFS100+crystal ( USD99.95 ) -- most expensive item, Magnetic coil servo+controlhorn+insert+carbon rod (USD26) and battery ( USD16). Looks expensive in all but most parts are easily reusable on other planes esp the RFFS100 unit which you probably need only to get one ( initially ).
            Hi. Thought I put up some pics of the plane in the air. These were taken this early morning 23 May 2005 at CCK Ave 3. I was blessed with another calm morning and was really delighted to see the plane cruising in the air.
              hello there!
              nice pics!
              rifqi.
                Thanks rifqi. Glad you enjoy the pics too.
                  Congrat! Cool plane, can share with us your plan?
                  JCho
                    Thanks Jcho. I like this plane very much. Credit has to go to the designer Thayer Syme and also Reddog at RCgroups & SFA (www.smallflyingarts.com) Forum who converted the plane to foam version. I have downloaded previously a simple blurred thumbnail jpeg of the plan from Reddog's RCGroup thread which I enlarged and traced the outline onto the depron. BTW, I have used 6mm depron for the main fuselage and 2 mm depron for the wing, rudder and stabilizer. A dihedral of about 1.5 inch was used on the main wing. Enjoy the plan and hope you have as much fun as I have with this plane.
                      hi like to find out where did you get the 2 mm depron ? Your assistant is much appreciated. thks
                        Hi Loyn. I got my 2mm depron online from depronusa ( www.depronusa.com ). How much depron do you need by the way ?
                          Oh from oversea....well should not be much as I have the same system you are using. I use balsa to make a 6 inch indoor plane but heavy ! Want to use the 2 mm depron to build another lighter airframe .....Are u planning to let go some
                            Hi Loyn. I can certainly spare you some. Could you roughly let me know the sheet area ( Length x breadth ) you might need. I still have a full sheet which is 48 cm x 74 cm. Also let me know how I can pass it to you -- where in Jurong ? What type of 6 inch plane are you making ? I have tried a number of times making planes of similar dimension but failed to get them flying well. I find them very unstable ( perhaps too heavy) with the DWE electronics. Kind of felt that the DWE electronics are better suited to 10-16 inch planes weighing less than 30 g. Maybe you can give me better advice in this area ?.
                              Congratulations! Sci_Fighter
                              It sure looks like a floater, Sweet Looking too!
