I recently had the chance to build and fly a Super AVA pro 3.7m glider.
It was an awesome experience, its has a 3.7m wingspan, flying weight of around 1700grams, RES control.
RCS brought it in for me to save the headaches of shipping. It cost around S$2K but varies according to the exchange rate, check with ken for the exact pricing now. I used this plane as part of a platform for my FYP project. I was looking for a thermal glider with very low wing loading and good stability. After considering many other gliders, I decided on this plane due to its strong following in RC groups.
The plane comes in ARF and for the price paid for it, I expected alot more work to be done. I wouldnt suggest this plane for a complete beginner as it takes some modelling skills to build it up.
Let me list the bad points first. For a 2K plane, I had to cut the vertical stabilizer's covering in order to fit the servos inside before resealing it which i was very hesistant in doing it but there was no other choice.
The fitting of the spoiler servos was a huge pain in the ass. (but then later i discovered this plane is better flown Without spoilers)
The carbon boom had to be cut in order to fit it to the fuselage. The fuselage didnt have much place to play around with the placing of the electronics. It was very very lucky on my part that i didnt do any CG balancing before cutting the boom and still got the CG roughly correct at the exact spot.
Fitting of outer wing panels was not exact and i had to file away some good to get it to fit properly.
The outer wing panels was intended to be held in place by friction ! which was quite crazy, so i added my own fibertape which had to be removed and replaced after every flying session.
For someone used to flying a 1.5m plane, I was wondering why this 3.7m plane felt so sluggish in turning.
OK, here are the good points.
ITS A DREAM TO FLY. I remember years ago I flew a very light hand launch glider called kyosho swing, this was like a monster version of it. Very easily controlled with just rudder and elevator, great floating capability. Very easy to slow it down to near stalling speed when landing. No tip stalling tendencies whatsoever. It takes practically no effort to thermal it, just climb to a decent altitude and cut motor, it signals thermals perfectly. It can be easily trimmed to be flown hands off with little input by the pilot.
Very grateful to my prof and the uni for allocating me this project.
But well now! Congrats Yeow Hwee!
