melody 43cc gas engin
    any one got experience break in and tuning this engin.need help
    tuning
    What sort of carb are you using?
    Try to start via 1 3/4 turns on H and 1 1/2 turns on L and when engine starts, warm it up, and go to max throttle. Adjust H to obtain peak RPM, reduce throttle to idle, then adjust L to attain a faster rpm, then reduce throttle some more until you can no longer go further without the engine quitting. From here, advance to full throttle and engine should transition to max RPM without bogging. If engine bogs, richen L by 1/8 turn.
      melody 43cc
      thank bro.
        A gd engine if run in properly...is this yur first gasser?
        stick to 20x8 prop..
        In The Hangar
        BH - SU26M - OS Powered
        BH - Edge 540 V3 50cc
        In The Dock
        Carbonic Boats - Light Ice IOM - Wind Powered
        In The Garage
        JQ The Car Yellow Edition - Novarossi
        FLY IT, SAIL IT AND DRIVE IT LIKE YOU STOLE IT
          my 1st is spe26 buy 2nd from my friend,but under power.
          change to 43,atually this is new but make trouble
          run in until one of engin mounting breake because
          a lot of vibration.
            a lot of vibration.
            bro,one of engin mounting breake because
            a lot of vibration-did u meant the wood engine mount..
            u might want to reinforce with fibre glass.
            by the way if u need another spe 43cc as spare i'm selling off my used spe 43cc @$150 as i'm giving up on gas as my kantana had already RIP.
            BESI KUNING MEMBER
              spe 43
              opp.if un lucky some time like that.
                43 cc
                not the wood engin mount,
                body engin mount and cos one of my aeleron servo came out
                lucky i can land my extra 260 safely
                p/s:pm u
                  G
                  well thats sucks...i guess u get what u pay...sorry to hear that bro.
                  so far having the monts break is not a rare thing
                  well for 150,,u get a gd set of spare parts...
                  btw bro..any idea how i can go JB n fly?
                  while u are getting spares...better get the RCExel CDI for it..i had a bitch of a time with the melody ones..
                  In The Hangar
                  In The Dock
                  In The Garage
                    s melody 43cc
                    i thing my cd ingnition is ok.
                    ur engin work ok,i mean if only the exsos dented is ok but if the sfaft bend
                    a lot of thing to do.
