I had a thought of catching thermal with a lightweight glider over hot sandy beaches, some months ago. I wanted to build a very lightweight glider, while using my 4 tiny Airtechnic AT-90 servos. However, I also thought of the method of launching to good height and found that discus style launch is the most practical method over our relatively narrow beach lines. So a DLG concept was adopted.
I also want to have a full house model so that I have the luxury of mixing spoilerons for more decisive landings, which is very important when flying over tight air and land spaces. The search the internet and found the Garnet,http://www.soaringusa.com/products/p...ategory_id=294, which should fit the bill. Not wanting to spend more cash, I used the specs and designed my own model. I remembered I chose Mark Drela's AG series airfoils, but I can't remember which one.
I started and finished the wing a 2 months ago but left it aside for my other projects. Only last week, I picked up some leftover materials and finished up the rest of the model.
Constructions are mainly balsa built-up structure with carbon wing spars and tail boom. Fuselage is balsa box construction with fibreglass reinforcements. Tail surfaces are sanded down from 1/8" thick balsa sheet.
The specs are as below:
Wingspan : 60"
Wingarea : 360sqin
AUW : 10.4oz
Wing loading : 4.16oz/sqft
Airfoil : AG series transitioning from root to tip
Servos : 4x AT-90
Battery : 4 cell 300mah nicd pack
Functions : aileron/spoilerons,elevator, rudder
I maidened it yesterday evening in very gusty conditions. The plane is currently slightly nose heavy and I didn't get very long flights. My launches are about 3-4 HDB storey high at the moment. Nevertheless, the model flies very well and the AG airfoil really allows the model to float down right to super slow speed. I did get a few small bumps to thermal today but yet to hit a real good one. Also, I need to further fine tune the model in order to get it best out of it. Right now, I'm looking for smaller Rx battery to get the CG right.
Wingspan : 60"
Wingarea : 360sqin
AUW : 10.4oz
Servos : 4x AT-90
